so i been messing with russian analogs of more common tubes, and my new fav is the 6n2p. they're cheap, robust, plentiful, and have a really great presence in the midrange going on.
they're only for fender style 6.3volt heaters.... some 12ax7's sockets are wired up for 12 volts, the 12ax can do 6 or 12, but the 6n2p can only do 6. but 6.3 is fine.
to start, go to tubedepot or whatever and get some socket savers, the kind that have a screw running thru them. check the pics.
unscrew the screw, and set the washer and screw and nut aside. i stand it up to unscrew it so the little nut just falls out. this is what the guts look like
here ya can see where i bent pin 5 across <with a slight arch in it to accomdate the screw>
and connected it to pin 9
to be continued
to be continued
