Hi all,
I've got a Carvin Valvemaster 100W head.
Recently it started completely dropping in volume, either warmed up or cold, without crackling, static etc.. It starts for no reason, gradually fading to zero. At that point I wiggle every cable, rotate every pot, tap on the chassis; nothing.
If I wait for a few minutes, the sound fades in gradually the same way like it faded out even if I don't touch the amp at all.
Time for a retube, right?
I swap power and preamp tubes, bias them and monitor for a few hours while playing guitar through here and there for 10-15 minutes constantly. The chassis is upside down at that point. As you can guess, no volume issues, although I don't play it very loudly.
After putting it in the headshell, carrying it over to the rehearsal space which is next door and playing for 10-15 minutes at similar levels like on the workbench, the volume cut happens again.
Any suggestions?
The schematic is for a Vintage 50 model because it's a first version Valvemaster, so same preamp but 4xEL34/6L6 tubes in the poweramp. I'm certain power amp works because there is sound coming out when plugging into return jack.
http://carvinimages.com/schematics/77501revI.pdf
Any suggestions?
