Help with peavey xxx switching problem
  • Help with peavey xxx switching problem
    Hello, first I will apologize for my bad English and grammar skills, its not my native language.
    My peavey xxx has a problem, when I switch to the crunch channel the lead channel comes on too, no relay click, ultra and clean seems to work fine. I'm switching with the front panel switch.
    I replaced the k3 relay with a 12 volt relay ( different type I couldn't find the same relay in my country ) I replaced Q7 Q8 Q10 Q11 transistors.
    I also dissembled the toggle switch and* cleaned the inside contacts, I removed the ribbon cables and soldered regular wires because they were loose.
    It will switch to crunch and the relay will click only if I touch the legs of Q7 transistor together ( collector and base )
    Here is a video :
    https://youtu.be/plLP_kOoduE
    Is this something I can fix on my own? Or should I give up and use it as a 2 channel amp because the are no techs in my country.
    Also my clean channel is way louder than the other channels, To get a good balance I set the clean volume just below 9 o'clock and my ultra channel volume about 2 o'clock, is this normal for this amp? Or is it faulty? Can I add some kind of resistor to the clean volume pot?
    And I should mention that I'm no technician, I get my simple knowledge from youtube.
    Sorry for the long post.
    Any input will be appreciated.
    Thank you
