I have a 1956 Silvertone model 1333 to re-cap and I found 2 pots wired as variable resistors between the plates of the 6SC7 & 6SN7GT preamp tubes and their power supply source voltage. The schematic I have shows normal resistors there. Could this be someones mod?
Silvertone 1333 tube amp
Thanks guys. The only thing these pots would tweek is the two preamp tubes plate voltage. I haven't worked with 6SC7 or 6SN7GT tubes but I'm guessing he was playing with their bias for whatever sound he wanted. It still seems a onnce and done thing since you have to take out the chassis to tweek.
Here's the schematic
Here is the schematic. The pots are wired to pin 5 of each preamp tube.
I'd think someone was tweaking the plate voltage (while disregarding the bias, which seems common) as you mentioned.
If the pots are rated 1/2W or better, I suppose you could leave them as is.
Out of curiosity, how far off are the set values from the stock values shown on schematic?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by frankeg View PostThe only thing these pots would tweek is the two preamp tubes plate voltage."Take two placebos, works twice as well." Enzo
I'm taking it back to stock. I don't care for his soldering either. He told my friend that he's had it since the 60's and it's completely stock. That doesn't jive with CTS pots from 76 & 77. I'll let you know the values once I desolder which will be a week or so when the new parts arrive. The more I see of these old amps the more I liken them to a box of chocolates, you never know what you're gonna get...
Originally posted by Chuck H View PostWell, no. They also change the plate load and that changes everything. Gain, current, bias, impedance AND voltage. With a pot as a plate load, and no other circuit parameters considered, it would be very easy to dial in an operational circumstance that is clearly undesirable (at best) or even dangerous (at worst).
Originally posted by frankeg View PostHence the blue and red colors right? Makes sense. Thanks for the insight!right away because I remember seeing these pots in TV's. I've never serviced them, but I took a few apart
It didn't click before mozz mentioned it and then I got a little kick out of it. Fun.
Originally posted by frankeg View PostYou are correct they are CTS pots made in 76 & 77.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
