hello world! suddenly my Road King has very low output when Loop System is engaged. when is bypassed frrom the rear panel switch ( master and solo pots disengaged) it works.
the V5 12ax7 is ok. I cleaned all the send / return jacks, I verified also the send potentiometer. all seems ok. I put a cable from the send output in the input of another amp - the signal is very weak.
I dont find the schematic for this amp.
does anyone had same problem? any ideas for restoring the amp back to life?
thank you very much!
