It makes sense to check and clean (Deoxit) fuse holder contacts of meter fuses after some years. The problem may not be noticeable in V mode but give wrong current and Ohms readings.
meter calibration
Originally posted by Helmholtz View PostIt makes sense to check and clean (Deoxit) fuse holder contacts of meter fuses after some years. The problem may not be noticeable in V mode but give wrong current and Ohms readings."Take two placebos, works twice as well." Enzo
I used to work in a Metrology lab, repairing and calibrating all kinds of test equipment.
Stuff in the lab at work is calibrated, so every once in a while I'll check my own equipment against that.
For troubleshooting or repairing amps meters don't have to be too accurate.
I have a Fluke 85. It has a REL button. Short the probes on Ohms and hit the REL button and it zero's out the probe resistance.
Whenever I go to a Pawn shop, I checkout the display case where they keep the meters. Sometimes you can find a bargain. One time I found a 2 Amp Variac for $15 because they didn't know what it was. Back when I ran a business, an extra meter or two came in handy. Never found a Fluke meter that had any significant calibration problem other than a blown fuse or worn out probe lead.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
