Hi, channel B of my amplifier was dead and found that 1 of the power transistors on the amplifier was short. Transistor was mj21193. i have remove the short transistor until i found a new one to replace it and amplifier is working most probably giving less power as all transistors are in parallel and the power of each one is added. the strange think that i don't believe is caused by the missing transistors is that on the specific channel the sound is distorted. Not much but if you try to compare the 2 channels there is a distortion on the sound. What you believe may cause this distortion?
Thanks
Thanks
