testing 7868s?
  • #31
    That's the CA4, I thought the SA-4 was different?
    SA-4 was the single adapter. Ca4 replaced them i think.
    http://www.antiqueradios.com/forums/...c.php?t=121108
    but with that info you can omit what you don't want.
    nosaj
    • #32
      "Read this pdf from the bama site . It states that the adapter will plug into the octal socket. It has everything youd need to build an adapter"
      Um, no. I have no interest in building that thing, it has 8 rotary switches, 5 tube sockets, 3 plugs, etc. I just want one single socket to socket adapter. Too bad that auction went dry quite a while ago. Looks like the guy built 10 and sold them all and moved on. They look nice, too. But at least it APPEARS that nine pine to nine pin is the right direction. This shouldnt be this difficult.
      • #33
        And with the information in that pdf should be enough instruction to build a single adapter you want that will connect to the octal plug on your tester.
        nosaj
