Marshall JMP-1 makes no sound - help please
  • Marshall JMP-1 makes no sound - help please
    I suddenly have no sound from any outputs including the headphones. Plugging into the loop produces no sound. The display seems to work fine. A couple months ago I replaced the 6 electrolytic caps, the encoder and the battery and everything worked fine until now. I don't see anything burnt. Transformer is cool to the touch and no burnt spots. Checked ribbon connectors. Swapped tubes. Reinitialized the system. These are the voltages measured to ground. I know the heaters are 12v so that looks ok but I don't know what the plate voltage should be. Any ideas on where I should be looking? Thanks
    V1
    Pins:
    #1 plate 2 - 124v
    #2 grid 2 - 0
    #3 cathode 2 - 1.024v
    #4 filiment 2 - 11.36v
    #5 filiment 1 - 0
    #6 plate 1 - 116.7v
    #7 grid 1 - 0
    #8 cathode 1 - 1.128v
    #9 filiment tap - 5.514v
    V2
    Pins:
    #1 plate 2 - 75.6v
    #2 grid 2 - .077v
    #3 cathode 2 - .644v
    #4 filiment 2 - 11.34v
    #5 filiment 1 - 0
    #6 plate 1 - 158.7v
    #7 grid 1 - 77.1v
    #8 cathode 1 - 76.9v
    #9 filiment tap - 5.63v
    You have no voltage on pin 5 of either tube, the second filaments. Measure from pin 9 to pin 4 and then 5. Should be ~6.3 on either side. If not, track down why. Might be a simple a a solder connection on the junction of pins 4/5 at either socket.
      He has 11 volts between 4 and 5 of each tube. 4 to 5 is the 12v configuration. These run on unregulated 12vDC.
      Are the heaters glowing? That is what matters to the tubes.
      But why are we concentrating on t eh tubes? This piece of equipment is really a solid state circuit with a couple tubes thrown in.
      So do you have both 15v rails?
      Are the mutes engaged?
        V1
        9to4 -5.82v
        9to5 -5.78v
        v2
        9to4 -5.92v
        9to5 -5.67v
          The tubes are glowing but I have to turn the light out and look close to see. They're dim. The heaters seems be getting voltage.
          I need to look a the schematic to see if I can measure the rails without pulling the board. If not I'll pull the board.
          How do you mute it? I looked thru the manual and didn't see anything
          Thank you
            Mutes are a function, not a feature.
            11v on the heaters is close enough.
            You don't have to pull a board to check for 15v power supplies. Look on the power pins of any IC in the circuit.
              I checked pin 16 on IC10, IC26 and IC32 and get 5v. But when I searched for data on the 74HC4027 (IC26) I found that 5v is correct. Maybe I'm not following your instructions? The data sheet shows pin 16 is vcc. Thank you
                Sorry, I made it unclear. Yes, your logic runs on +5. I had assumed that was OK when you mentioned the display worked. I am concerned over the +15 and -15, which would be pins 8 and 4 of the op amp ICs. Those are the TL072 or the M5201.
                  I've got +15.31v on the 5201
                    That is half the story, how about the -15v side, pin 4?
                      I just woke up +15.31v on pin 8 but only +.736v on pin 4 on the 5201 and the 072
                        So you are missing the -16V supply. Look on pg.2 of the schematic, at IC6 what voltage is going into pin2 ?
                        Does IC6 feel hotter than IC5? Or cool?
                          IC5 - warm
                          pin 1- +18.764v
                          pin 2 - 0
                          pin 3 - +15.314v
                          IC6 - cold
                          pin 1 - 0
                          pin 2 - +.572v
                          pin 3 - +.736v
                          I'm getting 18v at R85 and R86
                            IC6 is either shorted to ground on pin 2 or it is not getting supply. Since the part is not hot, I assume it is not shorted. Somewhere between pin 2 and the negative corner of the rectifier bridge, you have an open...I'll wager my lunch money.
                            R85.86 must be working, at least one of them, because you have the +15v supply, which also uses them.
                              Since the IC is cold and since the plus side of that supply works, I suspect you have a broken trace or cracked solder joint feeding IC6. Check the point of the bridge rectifier that feeds pin 2 of IC6. If you have -18 or so volts there and not on the regulator, there is a connection issue. My best bet is that the regulator itself has cold solder joints.
