Originally posted by nevetslab
View Post
Ampeg SVT
Originally posted by bsco View PostOk. Thank you very much....I will see if I can get at this over the weekend but if not I will be early next week......Have to work on the convertable top and mix up some concrete this weekend......busy trying to do some stuff here around the house.....thanks to everybody for all the help so far......I do have a question nevetslab......this thing goes into fault mode as soon as the power is applied....and in standby...I re-installed those 12a tubes and removed the output tubes....and same thing......so there must be a problem with the low voltage supply which I will check out.....that front panel light is supposed to light up red when it is powered up and placed in standby mode.....right??
I've never intentionally unplugged the High Voltage Secondary connections to the power amp PCB so the high potentials aren't on the board while troubleshooting the low voltage control circuits. They are discrete connections...J13 thru J18...right-angle insulated 1/4" Fast-on terminals. I've always managed to steer clear of the high potentials. If you're nervous about it, unplug them, but make sure to document it, so you know EXACTLY where each wire/connector has to go in restoring order. Happy hunting!Logic is an organized way of going wrong with confidence
I am back.......I did what you suggested nevetslab.....I disconnected the HV connections from the main board and taped them up.....and I removed the output tubes as well so they won't get damaged or cracked......when powered up and left in standby, the front panel light flashes......the 15V rails are down to approx. 4V each.....so I have a problem with the LV supplies.......now I can work without getting fried.......I have some schematics here from various sources so hopefully I have the right ones....the board number on this one is 2033854 REV E00.....I'll let you know how I make out......
Originally posted by nevetslab View PostOK....good luck on the hunt.
CheersLast edited by bsco; 08-17-2018, 10:08 PM.
Leave it to the previous mfgr owner of Ampeg to have selected 16V rated 220uF caps for C2/C27 with outputs at +/- 15V. Any time I have to dig into there, they get replaced with 35V parts, as the size is still suitable, lower loss/ESR. Sounds like you found what was dragging your supplies down. You might also check the two Thermistors CB1 & CB2 (look like 220pF ceramic disc caps...that small). I had just pulled two out on an amp that were very high in resistance for the function....40 ohms and 220 ohms. 2-10 ohm NTC 1/2A thermistors are probably what they should be. 10 ohm/1/2W would suffice in lieu of using thermistors there.
Cheers,
StevenLogic is an organized way of going wrong with confidence
Originally posted by nevetslab View PostLeave it to the previous mfgr owner of Ampeg to have selected 16V rated 220uF caps for C2/C27 with outputs at +/- 15V. Any time I have to dig into there, they get replaced with 35V parts, as the size is still suitable, lower loss/ESR. Sounds like you found what was dragging your supplies down. You might also check the two Thermistors CB1 & CB2 (look like 220pF ceramic disc caps...that small). I had just pulled two out on an amp that were very high in resistance for the function....40 ohms and 220 ohms. 2-10 ohm NTC 1/2A thermistors are probably what they should be. 10 ohm/1/2W would suffice in lieu of using thermistors there.
Cheers,
Steven
Originally posted by bsco View Post...I was thinking about mounting them in sockets and just running a very small dab of silicone on the ends of each IC where it meets with the edge of the socket....at least that way, if it ever comes back for repair it will be very easy to replace them....and the dab of silicone will keep them secured in the sockets while the amp is in use...
Originally posted by Tom Phillips View PostIf I may add my 2¢. A good quality IC socket will hold the chips sufficiently well without the silicone. I wouldn't add the silicone. It would look unprofessional and potentially cause contamination problems later.
Cheers
nevertslab, I got it working......I ended up replacing all those chips....I checked all the components in those op-amp ckts and everything was fine.....I went around and re-soldered all the connections to all the heavy parts and connectors..they looked ok but I did them anyway.....those capacitors and thermistors were fine......the only thing I am waiting on now is the fuse holder......the owner broke it trying to replace the fuse.......anyway, I should have the holder later next week...and I will be able to get it back together......Thanks for all the help......
Cheers
Originally posted by bsco View Postnevertslab, I got it working......I ended up replacing all those chips....I checked all the components in those op-amp ckts and everything was fine.....I went around and re-soldered all the connections to all the heavy parts and connectors..they looked ok but I did them anyway.....those capacitors and thermistors were fine......the only thing I am waiting on now is the fuse holder......the owner broke it trying to replace the fuse.......anyway, I should have the holder later next week...and I will be able to get it back together......Thanks for all the help......
Cheers
Cheers
Have a read through his post about matching here: http://music-electronics-forum.com/s...l=1#post477222Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
