Hi guys,
I'm doing maintenance to a 75 Vibro Champ. As usual I got high dissipation for the 6V6. I'm trying to address that issue but the results are kind of weird. I replaced the 470 cathode resistor with a 1K 5W one and the 25/25 cap with a 47/50.
The thing is that I get a voltage drop across the resistor of about 72.8 which is very high for the cap I used. And it's out of specs according to the schematic
I took some readings with the stock components, before the change:
PT red wires to rectifier 296.8 VAC
PT green wires to lamp and heaters 5.43 VAC
Filter section voltages 261.4, 278.5 289.2
Pin 1 V1: 190.6
Pin 3 V1: 1.2
Pin 6 V1: 187.5
Pin 8 V1: 1.12
Pin 1 V2: 130-143 value oscillates.
Pin 3 V2: 1.22
Pin 6 V2: 279.5
Pin 8 V2: 131-143 value oscillates.
Pin 3 V3: 269.3 (plate)
Pin 4 V3: 280 (screen)
Pin 8 V3: 55.7
Plate voltage on 6V6 is 55.7, already high.
I know that rising the voltage drop I'll drop the current on the tube. But looking at the numbers I guess I should rise the plate current a little bit too. I don't get why the voltage drop on the cathode resistor is too high on this one.
Any pointers on that?
Thanks a lot guys.
Carlos.
Pin 1 V1: 190.6
Pin 3 V1: 1.2
Pin 6 V1: 187.5
Pin 8 V1: 1.12
Pin 3 V2: 1.22
Pin 6 V2: 279.5
Pin 8 V3: 55.7
Thanks a lot guys.
Carlos.
