Hello Gang,
Here is another problem with this late 60’s Twin Reverb I have on my bench right now and I’m not sure where to begin. Take a listen to this video.
https://youtu.be/nHEtGRbXkmc
I’ve done a bunch of work on it and it’s sounding pretty good…except at full volume.
It sounds good to about 6. Clean, bold, big, Fender clean. When I open it up to 10 it falls down. Usually I would expect to enjoy dirt, grind, and overdrive (typical tones when you crank these old Fenders) but this amp is sputtering, spitting, low-end farting, and breaking up badly. It’s also got this “distorted ticking” sound almost like fast tremolo. I suspect the power section. I did change out all the filter caps and they should be good. I’ve got the tubes biased at 40mV. There are new tubes, and it’s pretty clean up to about level 6. At idle, there is no hum, ticking, crackling, etc. I got rid of all that using the usual methods (i.e. solid ground, plate resisters, pot cleaning, etc.)
Any thoughts?
Any thoughts?
