Some time ago I did some work on a friend's 1974 Super Reverb. The other day he told me it stopped working, no pilot light, nothing. We opened it up at his place and I checked continuity and found there was no continuity across the thermal circuit breaker (shown in attached photo) that was between the fuse and the power switch. I pulled up various Super Reverb schematics and didn't see any that showed such a device so I assumed it was not a mandatory item, nor had I come across one in any other Fender amp. We pulled out a soldering iron and I took it out of the circuit. We then slid the chassis back into the cab, hooked the speakers back up and fired it up. Everything seemed to work as normal. We turned it off and then tightened up the hardware and reattached the reverb tank. We turned it on again and got no sound. So now I have it at my house again. I looked through my resources and found the schematic I used the last time I worked on this amp. It does in fact have the "C.S.A Thermal Protector" indicated. The schematic is not a perfect match though as the amp does not have a master volume. Anyway, when I got it on the bench I started checking voltages. Basically I was seeing no output voltage from the 5AR4 rectifier tube that was installed. I checked it on my tube tester and it appears dead. I replaced the 5AR4 with a 5U4 that was handy and now have about 510VDC coming from the rectifier. However, I'm hesitant to run the amp in its current state since I'm not sure if that rectifier dying was just a fluke or because of what I did to the power circuit i.e. removing the C.S.A thermal protector.
So what do you guys think? Was it a mistake to bypass this thermal protector thing? Or should I throw caution to the wind and run with this 5U4 rectifier as is?
cbs_45w_mstrvol_pullsw_super-pro-bmstr_rev.pdf
