I've got an early 70's V4. I just installed a bunch of parts from fliptops.com. I put in new power and standby switches, and power and standby lights.
The power light was fine before I changed it out, the standby light didn't work and I assumed the lamp was bad. I bought the set and swapped them both out. Power light works fine but standby light still doesn't work.
Any help on where I might start looking for the problem? Anyone else had this happen? I haven't tested either light yet, which i should probably do first. Should I just hook up some voltage (like 5V) to it and see if it glows? Or do these run off of mains current?
That's a lot of questions...
