In my collection of equipment I have a BGW GTC Power Amp, a product I had designed and derived from the TRIAMP product, designed and built for powering Compact Monitor Systems small 3-Way Stage monitors back in 1989. This GTC had, at one point, been used to drive a film projector, using an Autoformer to step up the output voltage to 120VAC, and run it in sync with a video track. It worked for a while, then died. It was set aside for later-man to restore. That was back in the late 1990's. I finally dug it out earlier this year and assessed the damage. One module only lost two output pairs, while the other module lost all seven output pairs including one of the drivers.
I no longer had any of the full-PCB-size Bergquist K-6 Insulator sheets, so I was expecting to have to use greased mica, expecting thermoset to have set in long ago. I was pleasantly surprised that hadn’t occurred, and managed to get the PCB with it’s set of power xstrs up and off the heat sink without damaging the sheet.
The other amp module which only lost two pairs, I had removed the base and emitter resistors of those two, leaving the other 5 pairs in place, and checked to see if it would power up without any issues. It came up fine, bias still fine, very low DC offset, passed signal fine under load.
One of the omissions I made during the layout of the PCB & circuit was NOT using seven pairs of current sense resistors (one per pwr xstr), bussing them to feed the current limiter circuits (pos & neg sides). I had only used one pair of sense resistors. That was something I had wanted to correct, but never got around to it. Until today.
Also, one of the two amp modules that was in this GTC had a Vactec VTL5C4 retrofitted into the True Clip LED driver circuit (LED of Vactec in series with the collector of Q112) and an extra input series resistor (ahead of R115) to the front end diff pair, with the Vactec’s variable resistor tied to the middle of those resistors, other end grounded, so overdriving the amp would activate the Vactec, yielding an Anti-clipping function. So, I added one to the other amp module, prior to installing all the current sense buss resistors for the limiter circuit.
Physically installing the two sense resistor busses wasn’t difficult, though might be a little fragile, since I had to stand up all the resistors off of the PCB around the perimeter of the module, using 20AWG buss wire & Teflon sleeving between each resistor joint.
I’ve made the mod’s on both amp modules now. I’ll have to wait until tomorrow to check the results. The amp that lost all of it’s output stage also lost most of the emitter & base resistors, so all of those are new, freshly installed, along with the new current sense busses, so I’ll have to check that out after I get the first amp module powered back up to verify all is still ok with it.
I haven’t been able to add a layer onto the Adobe Acrobat 5 page and draw in or deposit a VacTec symbol and wire it up in the drawing. And now, CenterStaging has moved all of their administration offices to the new building down the street, so I no longer have scanning facilities here, without having to go there and back to hand-draw the mod’s onto an existing schematic. I’ll have to see what I can do when I get home in the document end of things.
9008-0760 Amp Schematic.pdf
