After replacing the Quad 6L6GC pwr tubes, I'm seeing the plate voltage swinging from around 420VDC to 395VDC and back, cycling at around a 1-2 second rep rate. I'm used to running into that when there's a Tremolo circuit running, but, no such circuit in this 3-Ch EVH 5150, similar to the Peavey 5150, but this is the Creamy-white EVH 5150.
It came to the shop from our rental inventory, no output (blown HT fuse), and after replacing it, I found it was pulling high current, from one pair of power tubes that were failing. Ordered a new matched quad set of J/J 6L6GC's, and upon installing the first pair into the bias probes, I found once again the max plate current I could dial up was 22mA. Tacked in a 100k resistor across a 68k resistor in the bias circuit to increase the neg bias, now having sufficient range to set up any set of tubes.
With each pair, checking to verify the matching, I was noticing the plate voltage cycling in magnitude. I wasn't seeing any variation on the AC mains current/wattage being pulled. Only about 1mA variation in the plate current seeing on the bias probe meter..
