I am working on a Peavey Mark III amplifier. Most of the original output transistors (SJ6357) are toast so I am going to replace all of them with replacement transistors (MJ15003). Should I also replace the driver transistors?
I would. Any time I have to replace a shorted output transistor, I replace the driver as well. Even if it tests OK, it was stressed by the larger part. they are not expensive.
Make sure to check all associated resistors.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostI would. Any time I have to replace a shorted output transistor, I replace the driver as well. Even if it tests OK, it was stressed by the larger part. they are not expensive.
