I have a small problem with a Deluxe Reverb, it sounds a bit compressed and seems to have little power.
The bias is well adjusted. But I see that there is more screen voltage than B +.
I replaced the filter capacitors with F & T. And I have tried to replace the power valves without any positive results.
I replaced the screen resistances with 4icon Xicon.
If I turn on the amp without power valves, the B + voltage is higher than the Screen voltage. But with the valves installed the b + voltage is 413Vdc and the Screen Voltage is 415Vdc.
This I think is not right.
Attached image with voltages in power section.
![](https://preview.ibb.co/c1Lhpp/deluxe_reverb.png)
