A friend bought the amp and had it shipped to him. When it arrived it had a broken input jack. He asked me to fix it, I figured an input jack no problem Opened it up and what a mess. Looks to be heavily modified as well as a few broken wires. Power trans obviously burnt up and was replaced at some point. When it burnt up it took out the entire power section on the PC board. Everything in that area has been replaced. It was not done very well but works so far. I fixed the jack and that’s when all hell broke loose. Fired it up on the limiter no problem, Fixed a couple of things then fired it up without the limiter, horrible sounding and all kinds of noise. I told him to send it back and get his money back but wants to keep it. It's actually worse than what I listed. Well now the fun begins.
A question, please correct me if I am wrong.
During the voltage check I am finding that the supply voltage for the bias is 90V. More than likely the wrong power trans installed. Would using a voltage divider be the way to go to drop the voltage to around 50V? Maybe using a 220K 1W and a 330K 1W (not sure of the Watt rating) for the divider. The bias for the EL34’s can only be set between -59V to -66V.
