Wrestled a bear today with a Marshall 6100LM Anniversary 100 watt that came in for blowing fuses. (guy owns 6 of them). I found an arcing ceramic socket and a HT transformer connection that was never soldered. To pull this board you have to unsolder all of the sockets as well as fight with the very agressive glue they glopped on all the connectors, I actually damaged one of the ribbon connector trying to get it off. So, I finally get the board out, futz with the socket, fighting with this heavy and very awkward chassis, (both transformers are on the same end). I eventually get it back together to my satisfaction, install the tubes to see how they are doing, switch it on and SNAP with a little puff of smoke, and then no sound. Damn it. I put one of the tubes in wrong, and shit. The keyways on these Russian 6n3C-E are maybe just small enought that you can do that, and I didn't check, which I normally do. Sigh.
So now I find the 470R 5W screen resistor on the socket is open. OK, fair enough. But it also looks like the 100R 4W is open as well, because I have HT on one side, but not the other. Now my question is, how is it they both are bad? If the screen resistor opens, then the short is gone and the screen supply resistor should stop being stressed. And if the screen supply resistor opened, the 470Rs would see no voltage, which is currently the case.
https://www.thetubestore.com/lib/the...-Schematic.pdf
