Have an Epiphone Chet Atkins here with complaint of "thin sound that is mostly treble with little bass response" (amplified) and a string balance problem - some strings sounded strong and others were very weak. Play test confirmed both problems.
Has a Shadow SH-091 under saddle transducer connected to an unidentified preamp that has volume and tone controls. The transducer was intermittent and the proprietary bridge saddle was broken on one end. My best efforts failed to duplicate that saddle with bone because the stock saddle was far too thin. So I replaced the transducer & saddle with stock parts and that cured the intermittence and string balance problems.
The instrument produces reasonable volume acoustically, but when plugged in the bass response is very thin, as if it is rolled off. Pickup connected straight to amp input, bypassing preamp, and bass response is much fuller albeit at a much lower volume. So I checked the preamp and found the K30A N-Channel JFET (out of circuit) had very high resistance between Gate-Source and Gate-Drain with the meter's positive lead on the gate. Resistance was 5.7 Mohms both directions.
Can this high resistance cause the "rolled off" bass response with this preamp?
Unknown Preamp
Stock Shadow Saddle Compared to Typical Bone Saddle
Unknown Preamp
