Dear MEF members,
I'm currently working on a Super Twin Reverb which came to me because of blowing fuses.
The first thing I noticed is that instead of having 6x 6L6, there were 5 x 6L6 and 1 EL34
Diode rectifiers and main power caps checked good despite being stock.
All screen resistors checked ok, I have noticed one has been replaced in the past.
I have also measured the DC resistance between the OT primaries and I found nearly 25 ohms on each side.
It sounds a bit low for me but considering the amp is supposed to run with 6 x 6L6 maybe I don't have to worry.
Are these values sounding ok for you as well ?
If so, then I would be ok to slowly power on the amp (without tubes) on Variac + Bulb limiter while checking voltages.
