My Deuce stopped making any sound whatsoever when I turned it on the other day. I made sure that all cables, speakers, power tubes, and the effects loop weren't the cause.
I opened it up and started taking voltages. I'm getting super low voltages on the power supply between the stand by switch and the drivers, but the rest of the power supply looks as it should, as well as the tube socket assy. I'm only seeing 6.6vdc on R4 and both IQ1 and IQ2 are reading just about the same on the base. Like I mentioned, all other TP's on the power supply look the way they should. I'm testing with an 8 ohm load with no signal.
Any ideas on how to proceed?
