Peavey's +/- 15V Regulator Questions
  • Peavey's +/- 15V Regulator Questions
    Hi, all.
    I'm looking into replacing the 7815/7915s on a Peavey Classic Chorus 212 and had a few questions. While I'm in there, is it worthwhile to upgrade to a quieter set? I'm unable to spec out suitable "upgrades" due to not having access to the specs on the stock parts. The only variance in specs across similar parts seems to be quiescent current ratings, and I can choose from between 6-8mA. Which would be ideal in this scenario? Seems moot, as this appears to be more about the VR's efficiency. Also, would it be advisable to up the capacitance on the filtering around them?
    TIA
    ~F
    "Ruining good moments since 1975"
    They're just regulators. Don't overthink it. No need to upgrade or change values of anything. Just replace the bad parts.
      I will abide.
      ~F
        And in general, we can look for quieter regulators, but it really is incumbent upon us to first determine if the existing ones are in fact noisy themselves. Data sheet potentials are not the same as real time measurements.
        casibom betturkey
