Frontman 212R took a hit PT bell cover hard enough to push the thin aluminum chassis in full inch. It is silent with no channel mode lights until something is plugged into the input, then it passes no signal except a loud dangerous sounding hum. It also has +40v on the speaker outputs, though I'll be dipped if I can see how it's getting there. I don't know if the two are related. I haven't pulled the board yet, but poking around in circuit I don't find anything that looks like it is shorted.
Q20 and Q18 don't look shorted. Same with Q16 (it's actually a 2N4401). C55 looks good (actually a 47uF, another misprint). D38 looks good. Those are the only paths I am seeing for the + rail to get to speaker out. Except for R101 thru R107, what's up with that?
Another interesting thing is the DC at the output goes away if I pull the input jack, so it would seem the mute circuit is in play here somehow.
FM_212R_-_Frontman_212R_Schematic.pdf
