So while you guys have been helping me with a Peavey CS800S in the "Other Amps" forum I picked up another project, a Crate GT500H. The GT500H is supposed to be the same as the VC50 (Vintage Club), which seems to have a pretty big following. The inside of mine appears to match the pics I've seen posted of the VC50 so I believe that's the case.
The on/off switch, standby switches and tube heater light, but no sound. So I did the pre-amp out to another amp's power amp and vice versa. Nothing. So I pulled the chassis and found that F2 fuse is open. I pulled the tubes and was setting up my current limiting bulb and found that I didn't have any 1/2A fuses, which was the fuse that was in there. Here's my quandary:
The PCB is silk screened "F1/2A, 250V"
The original (blown) fuse is a 1/2, 250V 312 and appears to be a fast acting
The VC50 schematic shows 1/2A SLO-BLO
A few other bits of info I notices:
The PCB is silk screened "2.5A, 250V" and has a SLOW BLOW paper sticker on the PCB
The VC50 schematic shows 2A SLO-BLO
Rev 7 on VC50 schematic states "CHG FUSES PER E960366"
The GT500H designation was before the aesthetic change to the VC series, so is older.
So I'm thinking that they changed the fuse call outs over time either because there were issues with the original fuse ratings or due to circuit changes as listed in the schematic revisions. I assume the correct thing to do would be to put a 1/2A, 250V fast acting in there, but was hoping to get some feedback from those who know WAY more than me.
As always, any thoughts, suggestion, etc., are appreciated.
Thanks!
Thanks!
