Acoustic b260 mkII no DI
  • Acoustic b260 mkII no DI
    Got an Acoustic b260 mkII with no DI. Not Finding a schematic anywhere on this.
    Once I verify signal is going to the DI board and hitting the jrc4560d.
    What I am supposed to see on the DI is 2 signals(one inverted) and a ground right?
    Thanks,
    nosaj
    Also what protects a DI when it doesn't require the 48 phantom voltage? Input diodes
    Slightly confusing post
    What does it mean: it has no DI output and youŽll build one or it has one which doesnŽt work?
    Ok, supposing you do have a DI circuit (on its own miniboard?)youŽll have to check functionality.
    Active DI are NOT true balanced and floating outputs which is what a transformer one does, but a simulation of it, sort of.
    They are really one preamp out, maybe straight from preamp or going through an Op Amp, feeding pin 2; plus a unity gain inverting section, made out of an Op Amp connected as an inverter, with typically 10k and 10k NFB resistors, feeding XLR pin 3 .
    So you have two Op Amp gain stages, one with gain=1 and the other with gain= -1 , feed signal and check how each one works on its own.
    To begin with, each one must have 0V DC at its output pin.
    Then if you feed it , say, 100mV RMS, you must find 100mV RMS at each output.
    If not,trace signal path to see where itŽs lost.
    Pin 1 may be directly grounded or separated from it with a switch called "Ground Lift", because ground is NOT required if device at other end is truly differential.
    See above: you must find original signal injected at each Op Amp output.
    And of course nothing on ground.
    If a sinewave, you wonŽt see "one is inverted", both will look like a plain sinewave.
    The balanced out stage does not *need* +48V 7mA , quite the contrary, but may fail or misbehave because of such voltage and current, so caps and resistors are essential, and diodes add protection.
      My apologies Juan. The DI was not outputting signal. They do recording with this amp so I thought it might be a possibility they connected the DI to a PA with phantom voltage engaged. But when I pulled the board out and started probing with the scope I found and electrolytic with a busted trace. Repaired trace and voila working DI now.
      nosaj
        Oh, no need for apologies in any way.
        Simply the first question was dubious and I asked for clarification.
        Happy it works now
