Originally posted by rpape2601
View Post
Now, with R82 fried, THAT IS a problem. The signal from the op amp IC8B passes thru to both TR5 & TR6 by way of those emitter resistors R79 & R82. If R82 burned open, you'd have no signal thru TR8, since TR6 wouldn't be conducting, TR7 would turn off, and no current would be flowing thru the bias string, so the output stage would turn off, and under signal drive, be very low and distorted.
The IC's in the amp are fairly rugged. I'd only worry about them if either of the zener diodes failed OPEN, allowing much higher voltage to be across the IC's.
What was the outcome with your power transformer? Last we read you weren't getting voltage from the power xfmr.
