Originally posted by rpape2601
View Post
Also, disconnect limiter coupling diodes D5 & D4 so the limiter circuit is out of operation of the main power amp circuit.
Did you replace TR5? it was shorted, based on the junction readings you made. With the 12V drop across R83 that biases the base of TR6, that's not normal. If you didn't replace TR5, then that 6.7mA current is probably flowing thru D2, D1, R80 and thru the shorted B-C junction of TR5, and also pulling similar current thru R78. If you did replace TR5, then there's way too much current flowing into TR6 base. There's already 4mA flowing thru R84, its' emitter resistor, so there's a lot of excess current flowing thru this level-shift stage in the amp. With 4.7VDC on the output, the circuit is out of balance, and I'm not yet sure what we have.
Make a full-page print-out of just the power amp schematic (with the power supply shown), and measure / mark the following voltages at: TR6 B, E, C; TR5 B, E, C; TR7 E, C; TR4 C, E; TR8 B, E; TR10 B, E, IC8B Pin 7, and the junction of R82 & R79. From all that, we can measure the current flow and see what's happening with the circuit.
Can IC 8 be bad? Yes, though it would normally go high or low, meaning it's output at pin 7 would be sitting near 12.2VDC or -14.7VDC with the current bipolar supply voltages.
