That "Secondary: 0.8 Ohm to unknown(8?) lug and 0.4 Ohm to 15 Ohm" is suspicious. It suggests that the unknown lug has more secondary turns than the 15 Ohm lug and that therefore it is not an 8 Ohm lug. (Assuming that the 15 ohm lug is really 15 ohms)
Originally posted by Helmholtz
View Post
I tried this method on a output transformer I know is working and the same result, working when bulb connected to the secondary but not the other way around...? Is this correct? I tested with a 9V battery.
