This amp came into my possession in really bad shape. It had a lot of work done to it in attempts to get it going by another tech. It has the toroidal style transformer that GK supplies when these original power trannies go.
I changed out the output transistors throughout the amp. Many of the bolts that hold down the cases of the 15025s and 15024s had broken from the circuit. I think I repair all of them....
One thing that's bothering me is the high voltage that's expected +/-85, here I'm only getting +/-70vdc. The +/-60v is present. Across the winding off of the power transformer is about 105vac. The lower voltage winding has about 90vac.
I'm not expecting this slightly lower voltage on the HV winding would be the reason for the low output but could this be a problem going forward?
I have a good clean signal coming out of both outputs of U1. But plugging into the effects return I'm getting a good strong sound.
When I link the pre to another amp the sound is very weak and distorted. So the problem seems to now be in the pre amp section.
I will post more as I trace through the pre amp.
