Did we determine if a power tube had failed? That many times takes out a heater fuse.
Fender TRRI bias issue. Help!
Steelwitch indicated that each tube was behaving under idle current. But I think that's all we know."Take two placebos, works twice as well." Enzo
With the present tubes, but did the 10A fuse blow while they were in use, or was it blown from before? Had a previous power tube failed then?Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostWith the present tubes, but did the 10A fuse blow while they were in use, or was it blown from before? Had a previous power tube failed then?
Originally posted by Steelwitch View PostCan I throw out a question to someone who might know? Why would these 220uf caps be reading over capacitance? It doesn’t make sense to me unless it was a manufacturing error. I tested them in circuit which could explain why they’re testing so high, but typically I get a ballpark reading if it’s within 10% of its rating.Logic is an organized way of going wrong with confidence
Originally posted by Steelwitch View PostWhy would these 220uf caps be reading over capacitance?This isn't the future I signed up for.
Originally posted by Steelwitch View PostI’m starting to wonder if my bias probe is not giving me the correct readings.. it’s giving me the plate voltage but not in mV like it should- Own Opinions Only -
Plate voltage is never in millivolts, unless it is absent. The cathode current in in milliamps, usually read as millivolts across a 1 ohm cathode resistor. Plate voltage will typically be several hundred volts.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Steelwitch View PostWait! Yeah I’m a huge dingus— just got them biased at 43.6 mA. I think we’re in the clear, I’m gonna put the output through my scope and give it the final check
I don't know who's bias probe you're using...whether you're using your DMM with the bias probe, or if it's a dedicated bias probe meter with probes....bias would be in mADC, plate voltage would be in +VDC, if there's a grid reading, that would be the applied bias voltage, in -VDC. Normally, the bias current is read with your meter on 200mVDC range. If it reads Plate voltage, it's scaled, and probably also read on the same 200mVDC range, as would bias voltage.Logic is an organized way of going wrong with confidence
