Fender FM212R Broken Control Shaft
  • Fender FM212R Broken Control Shaft
    So I get in a Fender FM212R that has a broken Treble control.
    The guy said all that he did was 'bump it with his knee' and the knob & shaft snapped off.
    A little research shows that the control is not available with the snap in legs.
    I found the non snap-in at Mouser and ordered it in.
    Got a new knob from Darren Riley.
    As I am disassembling the chassis to get the PCB out I snap off three other control shafts.
    WTF.
    Now, I have worked on a number of these amps without this issue.
    This poor guy had the same problem: http://www.mylespaul.com/threads/hel...ciated.400763/
Name:	Fender Amp 212r.jpg
    So I did some sleuthing and it turns out that the factory controls are a tad oversized for the knobs.
    If you push the knob down too far it really pinches the splined/ split shaft & sets it up for a fatigue failure.
    I used my heatgun to slightly soften the inside of the knobs when I reassembled the chassis to the original style controls.
    That will prevent future reoccurrence's of breakage.
    The non snap-in controls fit the knob fine.
    I wonder how many FM amps are like this?
    Or was it simply a run of oversized/ mis spec'd controls.
    Think I posted about this years ago.
    Really cheap metal pots, the shafts snapped with just the slightest pressure removing the knobs.
