This is the black knob verision, came in with the shaft pulled out of the Ch 2 volume pot. The push/pull is channel switching. First off, I had a bear of a time getting about half of the knob set screws to turn. They were so tight, some of them released with a crack using the biggest screwdriver I could fit. Then, about half of the pot nuts were on so tight I could not release them with my Excelite nut driver, I had to use a 9/16" socket and wrench. WTF.
When I got the board out I saw the pot body and switch box pushed back away from the chassis enough that everything seperated and fell apart as soon as I unsoldered them from the board. Tabs were bent, and parts were distorted like it took and awful hit. Yet, this does not reconcile with being bolted to the chassis and a big skirted Fender knob that would not allow this kind of inward pressure.
So I am left wondering, how did this occur?
