Fuse plug with circuit breaker
  • Fuse plug with circuit breaker
    Enzo sent me this with a bunch of other things I bought from him. In the past I'd just visualized a circuit breaker with alligator clips.
    I replaced the wires as the insulation was brokern, but thought I'd share what it looked like.,
    nosajClick image for larger version
    Seeberg used to use those fuses with integral caps. That is one of those fuses with a breaker wired in. I haven't used it in years. I still have a bunch of the red cap fuses.
    I bet you figured out the other stuff mostly.
    The large jones plug with 120v and two bananas for 6vac. That is for Seeburg tube chassis amps.
    The dual pot with a molex is for later SS Seeburg amps volume control.
    The giant resistor with clip leads - I use that in place of the field coil in electromagnet speakers.
    I forget what else I sent.
      I've often wondered why amps didn't have breakers instead of fuses, probably cost.
      I recently had a few amps with field coil speakers in for repair, so I made up a resistor with leads to jumper in for testing also.
        I did notice that fuse glass was a bit longer than ones currently used.
        There was a samsom wireless kit and and the delay kit you sent
        i can see the resistor coming in handy for sure.
        nosaj
          Some did... I thought Traynors & some of the big Ampegs of the late 70s? I remember getting one amp with one; maybe a Music Man? I don't remember...
          Justin
            Justin
            Traynors have that circuit breaker a mallory brand I believe. I've got a Bassmaster where the board went conductive so I've g10 replacement that I'll get around to one day.
            nosaj
              I'm not sure if this counts, but Heathkit TA-17 heads had a circuit breaker.
              DON'T FEED THE TROLLS!
                I know there was an 11 pin octal size plug, with internal jumpers. That is for Wurlitzer amps, it takes the place of the remote power switch that plugs into the chassis.
                  Yep I saw that too just didn't look inside to see the jumpers. Got it in the jukebox box. Keep them separated from amp stuff or I'll have a mess. Still have a lot of pegboard to put up.
                    "I've often wondered why amps didn't have breakers instead of fuses, probably cost."
                    Lab Series amps had them. And since they are a particular size and shape it makes it difficult to replace when they go bad, since they were stopped being made many moons ago.
                      I don't recall the numbers correctly...
                      But I had a broken off Labs Series breaker - it is also the power switch - seems to me I found SOME. But if the original was 6A, I found like 5A and 12A. SO I installed the 5A, and tossed the 12A in the bottom. I figured, add an internal fuse and use the 12A as the switch, and the fuse for the protection... if the 5A turned out to be to small.
                        While being convenient, breakers can be troublesome.
                        Like when a solid state output section fails and the owner keeps trying to power it up.
                        (Sniff, sniff. What's that smell?)
                        No different than putting in an oversized fuse which you have to hunt down.
                        Like I said. A bit too convenient.
                          Yeah, good point.
                          My parents house, built in 1962 had a fuse panel.
                          My dad and I replaced it with a breaker panel, upgraded be the service and split up a bunch of the lines to their own breaker.
                            Originally posted by nosaj View Post
                            I've got a Bassmaster where the board went conductive...
                            That makes two of us. The Traynor stuff didn't use the "wax soak" like the SF Fenders did. But I've had the waxed boards in those Fenders go conductive too. IMH(umble)E moisture absorption/adsorption for those black paper boards becoming conductive is not the only cause. I'm shooting into untested territory now, but I think the black pigment (carbon) under high heat, age and high voltage conditions can align to form semi conductive contact between eyelets.
                            EDIT: Oh, yes, some Traynors have circuit breakers instead of fuses.
                              Lots of Fenders built on that black card - and unfortunately also new kits using similar material - you can stick your meter probe wherever you want on the board, and I don't mean on the eyelets, measure voltage everywhere.
                              Can't say I've seen similar in Traynors, but it isn't impossible I'm sure. Their boards aren't crammed with carbon black, they look grey or tan.
