I have a drop dead clean 66 Vibrolux Reverb in for a new owner going over, and I noticed the OT was leaning to one side a bit. I found this stress crack has traveled half way across the front mounting tab. I don't want it to come loose, and am wondering how to fix it. The owner suggested a spot weld, but I am unsure if this is a good idea or not. Should I be concerned about the heat and/or electricity being applied to this 50+ year old transformer?
OT mount stress crack
I look forward to other suggestions...if it was me, I'd MacGyver it with Plumber strap (like for water heaters).
Remove the mounting frame from the transformer and replace it with one from a dead one or weld the broken one off of the transformer core and reinstall it when you're done.
There should be folded tabs on the bottom that hold the frame to the core. If you go this route, don't over do the bending of the tabs or you will break them off.
YES! I didn't think of that. Three of the four tabs broke right off, and I dont trust the last one, but I dont think they are all that necessary anyway. It was not easy getting frame off, as the laquer was sticking petty good, but it did come off. Now to find someone to tack it without burning through it.It's weird, because it WAS working fine.....
Since you have it off, you could also try olddawg's idea in post #4 and use solder and braid to reinforce the break. If so, clean well with a wire brush first and use plenty of flux. I've done this before with good results. If you lay a nice solder bead in the corner, it doesn't even look bad."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by mozz View PostI think a flux core wire weld would be the ticket. They use it for auto body panels.
All autobody shops I know of, don't use flux core wire.
They use plain mig wire with gas.
I have a mig welder and have used both types of wire.
The plain wire has far less weld spatter.If it ain't broke I'll fix it until it is...
I have just enough knowledge to be dangerous...
Originally posted by galaxiex View PostHmmm, flux core wire makes weld spatter (slag) a lot more than plain mig wire with gas.
