Marshall Mode four outputs
  • Marshall Mode four outputs
    I've got a marshall mode four with dead outputs. TDA 7293 Where would be a good choice to get these from ?
    I'm a little suspect on chinese one.
    Thanks,
    nosaj
    Nevermind I found them at mouser.
    https://www.mouser.com/Search/Refine...eyword=tda7293
    Just for the record, both those pictures show the V suffix (vertical leads). The HS version listed does not show the proper horizontal type leads. see datasheet for info
      Vertical leads are what I need
      nosaj
        On this marshall mode 4 I cleaned the fans real well they are quiet now and not sticking. Pulled the outputs and looking at all 4 2 of them have burn marks on them.
        Can I test this amp with 2 outputs on the master side?
        referencing this thread
        https://music-electronics-forum.com/...hall+Mode+Four
        Thanks,
        nosaj
          I jdid completed this repair on a MF350. . I performed the mod to the slave chips though I'm unsure what it does.
          Hardest part of this repair was clipping the old IC's out and removing the pins.
          Though the number one thing from this thread is the draining of filter caps before connecting the connectors. That right there saved a lot.
          Post 82 contains the relevant info.
          nosaj
          casinolevant levant casino
