Problem with the power amp, Q14 and R16 were open, must have pulled too much current.
Checked all the remaining transistors and diodes, emitter resistors, no obvious faults, but I'm getting around 4v across R15 and R27 on the other rail as soon as the red fault/power up light turns blue.
powering up with a light bulb limiter, the neg. side of sine wave is clipped until it warms up then will put out about 7v RMS and as the 90W limiter bulb comes on amp settles down with correct voltage across R16 & R27, but probably because the rails have dropped a bit being limited.
my base voltage on Q19 and 20 is fluctuating with no signal around 1.2v on Q19 and .2v on Q20.
Amp is pretty close to A1 Rev. and above in this doc.
So basically bias voltage jumping around/unstable and negative portion of wave clipped until warmed up in a few seconds.
Power supplies are all good and clean.
