I have a brand new Fender 68 Custom Twin Reverb that has loud LF & HF feedback, which a client just sent over. I preset the tone controls mid-point, volumes fully CCW. Reverb off Silver Face unit. After powering up in Standby, I finally switched into Operate, and began bringing up the Custom Volume pot ('Normal' Ch on regular Twin). Immediately greeted with loud LF feedback! Turned the volume back to 0. Grabbed the Vintage Ch Volume pot ('Vibrato' on regular Twin), and here, I was treated to loud HF feedback! Turned that volume back to 0. It was sent here due to the HF shrieking, as they put it, and supposedly only happens with the Volume past 5, and the Treble control all the way up. It's worse than that.
I pulled the chassis, brought up a 65 Twin Reissue schematic, not having the 68 Custom schematic. Looking at the output stage, I see V7/V8 with BRN O/T primary lead, and V9/V10 with BLU O/T primary lead. Checking to see which Org wire is connected to the grids, as maybe the output driver wiring is reversed??
From R45, that lead is showing up at.......V9/V10 grids, and from R44, that lead is showing up at.....V7/V8. So much for that theory. Driver, output tubes and O/T appear to be wired correctly. Checking the feedback resistor R39....connected to the Output Jack Tip. Wire color there is BLK, and to the GND terminal....BLU-GRN. Rats...that agrees with the schematic.
Any ideas on this one?
65_Twin_Reverb_SvcMan.pdf
Looking at the Preamp Stage wiring, there is a blue wire connecting V1B plate & V2B plate together. The cathodes for V1B & V2B are connected together at R23 as normal. Why would the two plates be connected here?
