Hey guys, I could use a bit of advice on a problem I've encountered with a Carvin Belair combo amp (schematic below). On channel 2 there is significant hiss when the "Soak" (drive/gain) control is turned up past a specific point (in the neighborhood of between 6 and 7 on the dial). I'm scoping a test signal at pin 7 of V2:B (with the channel volume all the way down) and as I increase the drive pot I can see the amplitude increasing on a relatively linear curve until it jumps up significantly at the point where the hiss starts and then continues from that point in a typical fashion. The hiss is not present on the other side of C13. According to the schematic I should see about 300V at the plates on V2. In fact, the actuals are 147V on pin1 and 246V on pin 6. Based on that information can anyone point me in the right direction as to what the issue might be?
Edit: I see now that there is a couple of threads on here dealing with similar problems with this amp. I'll start by looking through those.
Carvin-Belair-Schematic.pdf
