Blues Deville PR247 is in for a dirty sounding, and seemingly not loud enough sound. First I replaced the 12AT7 he had in the PI to 12AX7, and things got a little better. Tried different cab, 6L6s, probed around to no avail. Then I went from a GK bass head preamp into the power amp in jack, still breaks up and doesn't sound loud enough. New tubes are idling at 41 and 39 mA with 492 plate volts. Screens are a few volts below that. I have -51v on the grids. Feeding a sine wave I only get 17vac max into 8 ohms on my NOT true RMS meter, but by then the wave is very spiked.
Output transformer perhaps? If so can I use a 4 ohm 35watt OT for testing?
https://www.thetubestore.com/lib/the...-Schematic.pdf
