50W JCM900 Combo.
I'm injecting a 1000Hz signal. I'm getting a 2000Hz signal at the speaker. The scope says the signal on each EL34 grid is 1000Hz.
All grounds have been cleaned, different sets of valves tried, signal is being injected on 1st PI grid. (The effect was visible when running through the pre-amp, I just wanted to rule it out). Valves are biased to around 12W, DC grid voltages ~= -40V. Tried a spare output transformer. No difference..
If I pull either one of the EL34s the signal at the speaker looks as you'd expect - lopsided, but 1000Hz. With both output valves in circuit the voltage at the speaker approximately halves and becomes 2000Hz. Odd cycles slightly lower than even ones.
Suggestions?
Suggestions?
