Hello,
I'm presently trying to troubleshoot a TC Electronic Classic 450 amp in which there is no sound. The amp's owner reports that nothing happened when it was last used - just that one day he powered it up and it was in this state. The green LED on the front panel is lit indicating power on but there is no sound at the speaker at all. No hiss, hum, buzz, nothing. Also it appears that no signal is even getting through the pre-amp. With a signal at the input the compression LED's do not illuminate and there is no signal at the effects loop send. The obvious such as gain, volume not being turned up, mute button on etc. has also been eliminated. Also, there are no burnt parts or other obvious signs of damage inside.
The power supply seems to be good as the rails are measuring plus and minus 65VDC which are the correct voltages. However there is a red LED illuminated that is beside the speaker out jack on the same circuit board as the AC power receptacle. It is labelled "Protect" and "LED1". So it seems that the amp is in some sort of protection mode for some reason. The problem is that I don't know what that LED is supposed to indicate and have had no luck searching the internet so far. I'm also not able to find a schematic for the amp so can't get an idea from that either.
As a last resort before telling the owner that he'll have to send it to TC Electronics I was wondering if anyone on this forum would have any experience or insight into this.
Thanks,
Greg
Thanks,
Greg
