Hi all,
I picked up this poorly head recently and was told "all it needs are some power valves" - which of course hasn't turned out to be the case. Since opening it up I've found a couple of dry solder joints that were causing the head to go dead after a few bumps or pressure in the right places, but for the most part with new valves it's working, however, after buttoning it up and testing it on a speaker cab I found the reverb function has increasing hum as you turn the reverb up, turning it down again makes it go away entirely. I've had the reverb tank off, checked it inside, made sure the resistance on each spring is good, cleaned the RCA plugs, etc. I thought maybe the OPAMP IC for the reverb might be dying, so I removed the old one, popped in a socket and put in a similar 4560 while I wait for the exact one to arrive in the post, but this made no difference. I've double checked most of the capacitors in the region of the reverb circuit, they all seem good, I've been over the power section for it and I think it's ok, although the multiple grounds confused me a little. I've found a number of Valve King schematics, but not one specifically for the head, just the combos, does anyone here have the head version? Although they seem almost identical there are a few bits missing here and there.
Any nudges in the right direction greatly appreciated.
Thanks,
J
Thanks,
J
