I have a Fender SF Dual Showman Reverb amp on the bench, now past the re-cap of the 43 year old electrolytics and coupling caps, and found myself wondering about the Shield / Ground connection of the bottom of the Master Volume pot. It's sitting at the junction of the 820 ohm feedback from the output of the amp, bottom of the LTPI Cathode network, 100 ohms above ground. While I only have SF Twin Reverb schematics to go by on this, it looks to be the same thing in this regard. I see that connection clearly shown that way on the schematic. Is that correct, or is this a mistake made decades ago and, it being just 100 ohms above ground and part of that LT pair circuit, it doesn't matter. Why wouldn't the bottom of the master volume pot connect to ground instead of here? I haven't moved it....just wondering? I've pointed to the circuit connections in question with a green probe.
twin_reverb_sf_100_schem.pdf
