So I have a stock 70's DR103 with the bias voltage AC appx 356v. Its very anemic. I can get the new el34's to about 36ma at 503v DC with a bias pot added. But, I would like to see it around 30-32ma, not as hot.
Hiwatt dr103 Bias voltage to little
Here's a couple: (single and dual control)
https://hiwatt.org/Schematics/BiasCkts2.gifOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by The Dude View PostSure, you could build a doubler- no arguement. I have to wonder if you couldn't hit the goal with a simple resistor change or two, though.
Thanks for the link
Have you tried replacing the cap there? I think you should get more than 36VDC with 36VAC going to the diode.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
^^^^^^ I agree. I might also try upping the value of the 47k across the cap. I don't think you need a large increase in bias voltage to get to 30-32mA bias."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View Post^^^^^^ I agree. I might also try upping the value of the 47k across the cap. I don't think you need a large increase in bias voltage to get to 30-32mA bias.
"I'd try either changing it, or temporarily clipping another one across it to see if anything changes."
Yeah, but if the cap is partially shorting and pulling the voltage, what will clipping in another across it tell us?It's weird, because it WAS working fine.....
