To my "amusement", a Blackstar Series One 200 Bass Amp was sent over from inventory, label stating No Output. And here I thought all those Blackstar amps we have (had) were just for stage props. I love their design. One handle in the middle, with all of the transformers on one end, tubes at the other for good balance.
The AC mains Fuse holder was missing the fuse cap. Of course I didn't have one like it, so I first tried swapping it out with one of the stage prop chassis here in the bone yard. I gave up on that quickly, as all of those fuse holders deserved to be in the trash, so had to settle for one that uses 3AG style instead of GMC style fuses.
Seeing the KT88 tubes, I looked to see if there were discrete cathode resistors. Nope. Just one common buss that tied to a common 1 ohm 2W metal oxide resistor to ground. So, no simple way of assessing plate current balance. I powered it up, while in S/B, looked to see what was at the grids of the power tubes. -98V. This pot looks like it might be the bias pot (only one other to choose from), and diddled it to see if the bias level changed. Yup....-90V thru -105VDC. Put it back to -98V. Switched out of S/B, and no change in AC mains current, still sitting at 1A/112W @ 120VAC.
I only have schematics for the HT Stage 60/100 that I got off of this website, and looked thru it for some clues. While looking further for anything related to Blackstar 200, I came across Randall's thread 'Damn You Blackstar!', where he found after spinnning his wheels a while, it takes inserting a plug into the Input jack for the Bias to turn on. Cute. I plugged in my 100k termination plug, and sure enough, I had 88mA of current flowing thru the common 1 ohm cathode resistor, that settled down to 80mA. I did find Enzo's contribution to Blackstar documents 'Bias Guide General' and downloaded that. Many thanks, Enzo!
I finally plugged in my test signal, only to find the Clean Channel passed signal. The OD1, OD2 & Crunch channels all just yielded hum with the faintest bit of signal in the background. I swapped out the other three 12AX7's, one by one, leaving the 12AU7 in place, guessing it was the driver tube for the output stage. Swapping two of the tubes with each other, I did get the hum to go down, but, no passing signal thru those three channels.
I'm guessing it's on the Preamp front panel PCB....J175 JFETS, maybe one or more op amps, or who knows.
Anyone have the schematics for the Series One Model 200?
