Working on a Roadmaster. Schematic here: https://www.thetubestore.com/lib/the...-Schematic.pdf
Right now I am only working on the preamp. Normal channel is working fine. Lead channel passes basically no real signal. If you crank up the input volume you will get some really distorted garbage. Probing through the circuit the signal is clean up until it gets to V2. Signal is clean and strong at pins 1, 2, and 7. Almost nothing at pin 8 unless the signal is very big and then I get very small bumps at the peaks of the signal. Voltages all line up with the schematic. Have tried multiple known good tubes in V2.
Anyone have any idea what is going on here?
TIA,
Greg
TIA,
Greg
