Working on a Bassman 100 that looks like it has sat in a shed for 20 years. Currently powering up with 2 out of 4 tubes and an 8 ohm load. Amp powers up and puts out good signal, but after a minute or so I see an arc in a power tube and fuse blows. This has happened twice with two different pairs of tubes in different sockets. First time it was in socket 1, next time in socket 3, so not even same side of push/pull.
Schematic here: https://www.thetubestore.com/lib/the...-Schematic.pdf
I did later find and repair a broken solder joint, but it wasn't on the power tubes and unless there was oscillation I don't know if that could be the problem or not. Broken joint shown in picture below.
Replaced fuse, put first pair of tubes back in (checked for hard shorts on them first), powered up on LBL first, no bright light, power up normally, static coming to the speaker but have not put signal through it yet and powered it down after a quick check of voltages. Plates and screens all at about 478 and bias voltage at -52V.
Thinking I should probably retension the socket pins before I get too far. Any other ideas? Don't want to keep shorting it out as a troubleshooting method.
Thanks,
Greg
Thanks,
Greg
