Well the title gets straight to the point. So I have a Peavy Kb300 model KB-300-BW/ and I have no schematic and I have looked for the schematics and the one thats on this site is not the one. I will call Peavey tomorrow maybe they have it.
So I pull the amp out and proceed to clean the all jacks and the pots. This amp has never been maintained so it needed it, but surprisingly clean on the pcb and components.
After testing all the pots I discovered that the "mid" level which is the outer dial on these dual pots with concentric shafts. Channel 1 and channel 2 have no levels change when "mid" is turned, only a pop when the pot is set to 0 position.
Now that may be an indicator itself that it could be the pots themselves. Unfortunately I cant test the resistance of the pot without removing the board because the contacts are not visible, only the contacts for the center shaft.
Channel 3 works great and also lends to the idea that its bad pots on the other channels.
Does anyone know off hand if each channel has its own eq circuit or do they all share it. This would help determine if the pots may actually not be the problem. Thats it for now thats all I have. Any help is appreciated.
Also if anyone know where I can find these knobs please let me know,![Click image for larger version
and also where to find these pots as I have one that has a broken center shaft, and also why I need the knob
Thanks
Thanks
